2010 Mazda3 2.0L Overheating Issue
Hey guys, so I have a 2010 Mazda 3 2.0 that started overheating a few months ago so I parked it, well I started it yesterday and the thermostat never opened so I put a thermostat in it and topped it off with coolant (barely level with the max line) and expanded until it bubbled over a little and got up to 220f and finally opened up and ran fine and stayed cool so I drove it to work this morning with my scanner hooked up so I could get watch the temp and it never went above 203f. Well today on break I started it and watched the scanner and it got up to 237f, I turned the heat on and revved the motor a little bit and it went back down to 200f and stayed there but the coolant is still expanding in the reservoir (I bled the heater core when I did the thermostat) the thermostat is definitely opening because all of the hoses were cool when I started it and warm when I shut it off. What’s the issue here? Any ideas?
Your radiator fan is probably going bad if you can crank your heater and get the temps down. Or a bad radiator. Do these engines have electric fans?
I wouldn't think it's exhaust in the coolant (although that's cheap to test) since it would probably go very hot very fast.
I have a head gasket tester that tests for exhaust gases in the coolant I just haven’t had the time to go grab it from storage. It does have electric fans and they are turning on.
Then bad radiator or bad water pump? There's only so much that will gradually fail like this.
