And there she sits, mounted under the passenger seat:
I did end up running a turn-on lead from the head unit because it turns out that JBL's auto turn-on function sucks. I had to turn the sound way up for the amp to recognize the signal and kick on. Then if I turned it down to a normal listening volume, the amp would shut off. PITA
I am using the 4_channel MTX amp to biamp the front components for now. So the front channels power the tweeters through the JBL passive crossovers. The rear amp channels power the midrange speakers with no low pass crossover. The JBL passive put a full range signal to the midranges already, so they are meant to run this way. (See here and here)
So now the whole tuning rigmarole begins anew...
