2008 Nissan Altima Coupe
mikeyb
Contributor
01 BMW 325xi Touring
Conventional prejudice says you can't put a transverse V6 in a big front-drive car and call it a sport coupe. But after 600 miles with the 2008 Nissan Altima 3.5 SE Coupe, we're going to rise above our car-geek heritage and do just that.
Of course we're speaking of passion, not precision. This is still a 183-inch-long, 71-inch-wide, 3,290-pound car with 67 percent of its weight riding over the front wheels. Said wheels are wrapped in unassuming 215/55R17 Bridgestone Turanza tires.
But there's a vitality to the Nissan Altima 3.5 SE Coupe that defies clinical assessment. It likes going around corners. Its VQ-Series V6 likes being matched up with a continuously variable transmission (CVT). Even if the Altima coupe isn't dynamically perfect, we like driving it.
Minus Two Doors, Plus One Mustache
Nissan's starting point here has been the Altima sedan, already an athlete among family-friendly sedans. Instead of dropping a coupe body onto a sedan chassis and installing a set of really long doors, Nissan lopped 4 inches off the sedan's wheelbase (now 105.3 inches) and designed a fresh set of body panels.
With its 3-inch drop in stature and fastback roof line, the Altima coupe draws immediate comparisons to Infiniti's G37 coupe. From the back, it looks a bit too much like the innocuous Pontiac G6, but wheel around front and there's a wisp of a chrome mustache to reassure you this car has the evil, funhouse flavor of the Altima.
We Choose Torque
As usual, there are degrees of evil. Not so threatening is the 2.5 S Coupe, which is motivated by a 175-horsepower 2.5-liter four-cylinder engine and priced around $21,000. Nissan says this car will account for 60 percent of Altima coupe sales.
We're speaking here to the other 40 percent, however; the fiends who will spend upward of $26,000 on the Altima 3.5 SE Coupe. It has a 3.5-liter V6 rated for 270 hp at 6,000 rpm and 258 pound-feet of torque at 4,400 rpm.
Although a six-speed manual is available, most 3.5 SE Coupes will be sold with a continuously variable transmission (CVT), with which our test car has been equipped. Most will also have the $3,200 Premium Package good for xenon headlights, leather upholstery, Bose sound and automatic climate control.
Our test car did without the premium luxuries. Antilock disc brakes and all the expected airbags were on board, but stability control costs $600 extra.
Quick by Numbers, Quicker by Feel
The lack of amenities went largely unnoticed, as the Nissan Altima coupe has other ways of making its driver feel energized.
It's not with overpowering speed, though. A 0-60-mph time in the 6.0-second range and a quarter-mile time just under 15.0 seconds no longer make anyone feel entirely special, not even in the sensible coupe class. Our CVT-equipped coupe ran to 60 mph in 6.4 seconds, then laid down a quarter-mile in 14.8 seconds, a couple tenths quicker than the Altima sedan.
Nevertheless, it hasn't any edge over the Pontiac G6 GTP coupe, which gets to 60 mph in 6.2 seconds and does the quarter-mile in 14.8 seconds. Of course, the Altima CVT coupe is a smidge faster than the Mitsubishi Eclipse GT with a manual transmission, which takes 6.6 seconds to get to 60 mph and then does the quarter-mile in 14.9 seconds.
But away from the test track, you'll be convinced this is a fast car. Partly it's the sweet power delivery of the VQ V6, which offers just the right balance of smoothness and personality in this grand-touring application.
Get With the CVT Program
Mostly, though, the Altima coupe's lively performance comes from the CVT, which makes good on the promise that a CVT is better than a regular automatic transmission. Instead of playing telephone with your right foot, sending a message to the engine through hydraulic fluid whirling around a torque convertor, the CVT responds immediately to changes in throttle input. So when the engine rpm soar, it's because you will it.
During instrumented testing, it made no difference in the numbers whether we left the CVT in Drive or used the manual mode. But on your favorite back road, there's good reason to call up a manual "downshift." Pull the central gearlever back as you're coming into a tight turn and you gain access to a usefully lower range of available gear ratios.
So enjoyable is the CVT that even hard-core drivers will prefer it to this car's manual gearbox. You see, apart from the pleasures of post-redline upshifts and heel-and-toe downshifts, the six-speed is a weak effort. The clutch engagement is abrupt and the shift lever feels limp through the gates.
The CVT also delivered pretty good fuel economy. The CVT coupe achieved 34 mpg on a pure highway run, although only half that during a workout on the two-lane averaging out to 20 mpg. During the brief 200-miles time we had our hands on the coupe with a manual transmission, it returned 18 mpg.
Coupe in the Balance
Handling is another area in which the 2008 Nissan Altima 3.5 SE Coupe reaches out to its driver. Its 68.8-mph slalom performance and 0.81g grip on the skid pad are no better than the sedan's, but there's a psychological component to the coupe's compressed dimensions and slightly lower curb weight. Maybe it's just us, but the two-door feels hungrier on a curvy road.
And compared to the understeer-prone Eclipse and unresponsive G6, Nissan's new coupe borders on the ravenous when it comes to eating up the road. It's also much quicker through the cones on its skimpy 55-series 17-inch tires than either rival is on low-profile 18-inchers. The Altima has the edge in steering feel as well.
The Altima's braking capability is only average, though. A 127-foot stop from 60 mph brings it to a halt 10 feet shorter than the Pontiac, but still not up to the Mitsu's 124-foot performance. The Altima's brake pedal travel is short and there's lots of initial bite from the brake pads, but the tires just aren't up to it.
Because of the Altima coupe's shorter wheelbase, you feel the impact from highway expansion joints more sharply than in the sedan, so you'd better have a tighter grip on hot, splashy beverages. Overall, though, the coupe's ride quality is agreeable.
Functional Cockpit, Funky Seats
Just as in the sedan, the cabin of the 2008 Nissan Altima Coupe has a vaguely industrial ambience, although it features simple, well-organized controls. The soft-touch plastic that trims the dash feels rubbery to the touch, and the action of the various dials feels grainy and unpleasant.
The coupe has less headroom than the sedan, of course, and the front seats now have considerable lateral bolsters to hold you around corners. Rush-hour comfort is debatable, though, as the driver seat combines a slightly odd overall shape with firm cushions.
The coupe's trunk space is minimal at just 7.4 cubic feet, but it's a useful space with a wide opening and the 60/40-split rear seats fold completely flat, providing a cargo area large enough to bring home an awful lot of dry-cleaning plus some groceries, too.
Best of the Front-Drive Coupes
When you set out to buy a midsize front-wheel-drive coupe, you have to be willing to make some tough choices. If you've got a specific craving for a more decadent rear-drive car like the Ford Mustang GT or Mazda RX-8, you shouldn't ask an Altima coupe to satisfy it.
But if you're willing to admit that ride comfort, fuel economy and interior spaciousness are important, then the 2008 Nissan Altima Coupe is one of the best options out there. Among the current population of V6 front-drive coupes, the 3.5 SE is by far the best drive.
- Insideline
I'm really wanting to go testdrive one of these. But it has to be a VQ35 with a 6spd.
subbin to read later! Thanks for rhw good post. Can't wait for your driving impressions.
I wouldn't mind one. But something in the back of my mind would have told be I settled. Not a bad car for what it is though.
Nice car, good engine. Not complaining, just an observation, I thought that with that much HP and displacement the car would be faster (acceleration)...IHMO. I mean look at the MS3, or MS6 even (which would be a more appropreiate comparision). Very nice, but I think the MS6 still has a bit more of an edge.
The one area where my MS6 falls short of my 3.5 Altima is power below 3000 rpm. The Altima had power pretty much anywhere on the tach, where you need to keep the MS6 more 'on boil' to keep things moving. But...the AWD is so much nicer than the torque-steering, tire burning traits of the Altima. The 3.5 6-speed would be the only way to go...just set aside a tire budget.
What year Altima? The torque steer has just about been elimated on the 07s.
BlackCherry06 said:
Mine was an '02 5-speed. I went through the factory tires in 12,000 miles. (Not difficult...they were Turanzas.)
s*** tires. I put about 18K to 20K and I changed them to Kumho ASX which I've had on for just over a year. I've put about 20K in the ASXs. Alot better tire and quiet.
