2008 CX9 hvac drain clogging
doggun
have a 2008 CX9 and have had to crawl under the car and drain suck out the drain twice in 1 month any ideas? Is there another drain someplace?
I had to do the same thing - the drain kept clogging. I tried the compressed air trick first, which unclogged the drain and allowed about a gallon of water to come out. However, it clogged up again shortly thereafter. I then used a shop vac and rigged up a hose and vacuumed it out. It then clogged again a little while later. After the second vacuuming, it has not reoccurred.
Keep at it, eventually you get all the gunk out of there.
Nope. That's it. I've never had this issue but I'm garaged always. Gotta get under there from what I heard. Sorry!
