2007~2015 CX-9 GT Multiple codes and rough idling/accelerating/braking
jplee3
Hi all,
My wife called me while driving it home the other day and told me the car felt "rough" particularly when she accelerated, while braking, and I'm pretty sure while idling too. I pulled out the OBDII reader and ran a diagnostic on it. I didn't start the car up or anything initially but just turned it on to check for any codes. This is what came back:
P0304 – Cylinder 4 Misfire
P0204 – Cylinder 4 Injector Circuit
P0174 – System Too Lean (Bank 2)
P0016 – Crankshaft Position / Camshaft Position Correlation (Bank 1 Sensor A)
A while back when I had an ignition coil issue with #5 and swapped it with #6 and it seemed to have resolved, I had ordered some new Denso (likely OEM) ignition coils JIC. The next day, I went ahead and replaced ignition coil #4 with the new Denso just to see if that *might* resolve any of the codes.
Started up the car and noticed a slight rough idle. I plugged in the OBDII reader and put it in live mode then let it idle more and took it for a short drive up the street and back. I'm pretty certain I experienced the same behavior my wife was decscribing when she called last night.
I also heard what sounded to be a creaking/squeaking noise when accelerating or reversing, so I'm wondering if that might be related to the crankshaft code...
Anyway, after that a couple of codes returned:
Also, STFT Bank 2 is +35-45% where STFT Bank 1 is -8% and dropped while driving, which I think indiciates imbalance in fuel distribution.
I ended up pulling the voltmeter out and confirmed no ohm reading on the #4 ignition coil so it looks like I'll have to replace it. #5 & #6 were fine. I'm sure I'll want to test the others as well.
As a side, I also noticed some exposed and frayed wiring...sigh:
AP1GczPxYfaULHatZ-kxi47NKAWN9XGgU-2oq9Dwk5RiRjURJXcPTUrtI4kR6d_UOmO1NT4j6ap57p_qpXwDtE4zITlf7YIxkCMquqz7ocjAi3qXtvq2OSyYPrC64Y2MoKaiApoQsYjPhw4zvYd3wDnf4ZSarQ=w2119-h1589-s-no-gm
Question: for the P0016 (Crankshaft issue), I wonder if that would be a biproduct of P0204, etc... has anyone seen this come up as a result of cylinder issues and get resolved once those other issues were fixed?
I stumbled across this older thread as a reference point into DIYing the repair so planning to do that (although not looking forward to it):
I've also ordered some parts: a couple OEM fuel injectors, new gaskets, 6 new Motorcraft platinum spark plugs, and some spare wiring and tape to make some splices on the wiring harness.
