But that works on the 08? I tried everything a while ago other than disconnecting my battery and it didnt work.
ok I FINALLY got my 2008 5dr S mazda3 to do this today!!!!!
Here is what I did; some steps may not be necessary.
FIRST
A) I have the 6 CD in dash CD player
B) By turning the ignition to ACC and holding [AM/FM] and [CD] I would get "DIS ON" but the trip computer would not function.
What I did that worked:
1) Disconnect both terminals of the battery.
2) Wait 5 minutes, (I took the time to clean my air filter)
3) Put the key in the ignition and attempt to start the car.
4) Reconnect the battery positive terminal first then ground.
5) Get in car, CLOSE the DOOR.
6) Hold [AM/FM] and [CD] buttons down and then turn key to ACC (you dont need to waste gas) while still holding both buttons.
7) Release the 2 buttons when the stereo Displays "DIS ON".
8) Turn the car back off.
9) Start the car and the trip computer will be where the clock was.
To toggle to the clock use the [CLOCK] button.
To toggle to the trip computer hit the [:00] button.
To toggle between menus while in trip computer mode use the [:00] button.
CONSUM CUR is instantaneous mpg
COMSUM AVG is the average mpg since last rest
The other two are miles to empty and avg speed
TO reset the trip computer hold [:00] button while in trip computer mode.
Please repost this where appropriate.
Hope this has helped many!
Cheers!
Jeff
FIRST
Cheers!
Jeff
I think for the 08.5 you need to point the car due north, open the right rear door and glove box. Walk counter clockwise with your left hand in your front pocket twice around the car then close everything up, grab a beer and hope Notre Dame gets beat this weekend.
I gave up...Mazda figured it out and locked it up...
What is the difference in the 07 head units ???
Like I said on another post in this section. I have an 8.5 metro sport and followed the original directions and it didnt work. I did it a few times and tried a few different ways and all the sudden it came up. I never took off the battery cables and i can only play one cd at a time. I will not try to figure out how I did it because I may never get it to work again but thanks to the original thread it worked for me.
The 6 CD players, are they MP3 Compatible? I'd swap one out on mine but it's gotta be MP3 compatible or else not worth it.
My '08 GT headunit doesn't play MP3 discs. I believe the '08.5 and '09 models do though.
