2005 Mazda3 2.3l Oil pan replacement question
First time user, registered just to ask this question. My 2005 Mazda 3 2.3L sedan is leaking from the oil pan. I'm looking around for an oil pan and want to know is it normal for some to cost $200, and others up to almost 2K? They even look different. I'm assuming going with the cheaper / smaller one isn't the best idea? The shop quoted me for a SPECTRA PREMIUM MZP15A at almost 900. I'd rather spend $2-3 on the smaller one, if it'll work. I'll post a pic, any advice is helpful. Thanks in advance.
Your Oil pan has a hole in it? Usually leaks are from the gaskets.
Not sure they look different to me. They are not oriented the same so it's hard to tell.
At that kind of money, assuming there really is a hole in it and it's not simply a leaking gasket, I'd braze (or weld, but a lot of people don't have a setup to weld aluminum) the hole shut. Brazing will only cost you the time to pull the pan and clean it. A rod is like $1 tops.
