2004 vs. 2005?
russr
Mazda6 6i 5-door 2004
I'm looking into getting a new Mazda6 and was wondering if there was an advantage to getting a 2005 over 2004 (both new). There is a 60month 0% interest financing on the '04, and a 36 month 0% on the '05. Otherwise they are the same financially.
What are the advantages to each overall? It seems like the major functional difference between the two is that the '05 comes with more standard, but in the end MSRP is almost the same.
If your going MTX it doesn't matter (unless its a 6i). If your going ATX, you want to make sure to get the 2005 Mazda 6s...which has the new 6spd ATX transmission. It doesn't have the overheating issues of the 5spd Jatco, nor any of the shift shock issues, and shifts much faster, crisper, and gets better mileage then the old ATX.
An 05 6i MTX might be worth getting as they fiddled with the gearing ratios slightly.
I'm going with the 6i MTX as I mostly do city driving and I want the better mileage.
So does it matter that much if I go with 05 or 04 in this case? How much better are the gear ratios on the 05 6i or are they even better?
Transmission Info
http://forum.mazda6tech.com/about8.html
Here's the gearing for easy reference.
6i MTX Gear Ratios
03-04 vs 05
1st 3.307
2nd 1.842
3rd 1.233
4th 0.914/0.970
5th 0.717/0.755
Final 4.105/4.388
Good choice on the 6i MTX btw, its only 3045 lbs! W00t. Have you looked at the Mazda 3s MTX by any chance? Same engine as the 6i MTX, only lighter and smaller. 2762 lbs to be exact.
Thanks for the info crossbow, but I'm not even sure what those ratio changes translate to. At this point, if I get an '05 I have to special order it and that's going to take anywhere from 1 month - 4 months. In the end I don't even know if I'd notice those gear ratio changes. I save a bit more on the '04 as it has 0% financing for 5 years and a pretty aggressive lease program which drops the price of the car by like 1-2k. Lease programs on '05s are good too, but waiting all those months for it sucks.
Given the above, do you really think I should go for '05?
Technically I think the 04's 6i MTX is lighter :). (Due to packaging differences).
I guess it really comes down to the packages you want and what not. Its hard to get certain packages on the 04 6i, where the 05 6i comes with some standard.
I got a fully loaded '04 6i hatch lapis blue with beige leather. It has it all ranging from luxury package to that crap bose audio thing (won't make good use of it) that I had to get for the side airbags and moon roof. The only thing is that it has beige leather instead of black. I prefer black but gotta special order that in an '05 and not sure I wanna wait a couple of months for that.
What do the gear ratios changes on the '05 actually mean?
BTW, to answer your earlier question, i did look at the Mazda3, but I don't like the look of it as much as the Mazda6. In addition, it's kinda small in the back seat. Main thing is the look is not so appealing to me like the way the 6 is. Like the better handling, throttle response and mileage on it though.
russr said:
Any tips on breaking in this new 6i with mtx?
Drive the living piss out of it for the first two weeks and it should be fine after that.
he asked about breaking it in ya wait till about 3000 to really get on it drive conservative and just to be safe since it is a new engine do your first oil change at 1500miles or so
Do your first oil change at 1000 miles, and like Mazda 3 said drive the living sylights out of your car for the first 2 weeks.
Manual states to go "easy" on the car for the first 600 miles.
There are variety of articles online which state that "excessive use of the throttle = good breakin" but don't take into account there are a variety of other components that require a bit of "easing in" to breakin.
So what do you do? Meet somewhere in the middle. Don't go "easy" on your car, but don't bash the hell outta it.
Make sure you vary the throttle rpm's for the first 1000 miles (no cruise control!!!), and make sure you go through the ENTIRE RPM BAND. This includes nippin into the redline area. Don't bounce off it as course, but also don't be afraid to use your car. Avoid sudden stops, and avoid harsh starts (no clutch droppin).
As as everyone said, early oil change = great idea!!!! Breakin miles produce more then 30x normal wear metals in your engine oil!
I followed the "vary your rpm" system and ended up with the highest 6s ATX dyno (stock) to date of 165 whp. That doesn't sound like much, but some 6s ATX's with intakes and exhaust have dyno'd 5 less hp then mine did stock =/.
Crossbow, thanks for the advice, but I'm a very new mtx driver. In fact, I had my first lesson just the other day, so I'm not really sure how to do what you suggested. Is it basically just late shifting? I didn't think redlining was good for the engine.
Also what do you mean by "don't bounce off it as course"? I'm also not sure what going through entire rpm band means.
As far as starting goes, should I gently ease off the clutch until the car barely starts moving forward?
speed 6 might not be gas friendly but fun facter definantly overrules that ;)
This debate takes place a couple times a year on every car board on the net. You'll find the the small group of people that know what they're doing break there cars in hard. These cars always end up running the best. Like crossbow said he broke his in hard and came up with the most stock HP. I have dozens of examples like this to back up this theory. Its not just HP either, I find they get better gas mileage too, if broke in hard.
The main thing I guess is to do what you're comfortable with.
I'm all for breaking it in hard if that will improve the mileage and overall performance of the car. Check out my response though to crossbow's post. I'm a brand new mtx driver and I need some help in doing what he said to do. (confused)
I didn't drive hard...I just varied the rpm's. I basically left the dealer (weekend), got on the highway, and went in the slow lane, and sat there like a jack ass shifting gearings so I could constantly move through the rpm band. Consistent accleration and decceleration.
I'd go from 40 mph, up to 70 in various gears, then let the engine slow itself back down, then repeat 3-4 times, then drive normally for 5-10 minutes, then repeat.
I'd say if this is your first MTX, (as this was mine), you'll break in the car fine just trying to drive it :).
slow lane in md? is the the far left or the center? but yeah vary speeds and lightly break it in....no autoxing till like 3k on the odo
