2003 Mazdaspeed protege won't crank???
NvMySi
Alright guys so previous owner had the same problem everything worked but no power to the starter so ge towed it to Mazda and got something reset??? And started no problem me as a new owner it happened to me as well so we removed the factory Mazda alarm was very simple and still won't start , everything works but the starter , sounds like a kill switch between ignition and starter? Or is there a way to reset this myself? Or remove this kill switch wherever it is ? Any help would be appreciated thanks guys.
There is a button for the alarm under the dash, unless you removed that too. It may have a bad CMP, CKP, or MAF sensor as well. Could even be a bad ECU or starter. But it's probably a blown fuse and a short somewhere in the circuit.
in the car audio section....
by crank do you mean it doesnt get loud enough?
the basic ways to get more volume are more power and/or more cone area. how much space do have to give up?
