This is in reference to a 2000 Protege 1.6 Auto w/o having to start another thread.
I finally got my alternator belt & P/S A/C belt changed today, and yes
for the first time at 116,168 miles (eek2)! My belts (especially the alternator) have lost over 65% its ribbed grooves...still not bad for its lifespan. I tried doing it myself - after a good 2 and half hours or so with bruises all over my arms (because I REFUSED TO GET UNDER THE CAR with the support of
only a small a jack) and I gave up!
Before that...
...while trying to loosen the pivot screw from the bottom of the alternator, I loosen the other (perpendicular) screw, adjust the tension screw and couldn't figure why the alternator and the belt was still so stiff. Then I found out the socket from the tool that I was using had split therefore creating a soft friction turn. I actually thought it was loosen, but not, it was the damn broken socket! I couldn't believe my eyes (never buy those $10 mechanic's tool set from PepBoys)! So I quickly put everything back together as this is GOING NOWHERE; this includes the front passenger wheel, plastic cover by wheel well, a couple of electrical elements on the engine bay for easy work access, unjack and lower the car, etc. A frickin' nightmare!
I called my mechanic and rushed down there (you know how happy Friday afternoon traffic is) just shy of before closing at 6PM.
Total cost breakdown:
$15.41 - Mazda OEM Alternator Belt - Mfg by Gates (B6BF-18-381-9U)
$9.68 - Mazda OEM P/S A/C belt - Made in Japan (BPE7-15-909)
$16.00 - Oil Change (Oil & Filter) decided to do this while I'm there.
$30.00 - Labor for the belts
$71.09 total (no taxes)
No squeaking and quiet as a mouse - I'm just crossing my fingers.
The Protege runs a bit tighter, the a/c unit didn't intermittently vibrate as hard as it did before and the power windows roll up a bit faster (it was hesitating before).
The problem was I didn't have the right tools and I didn't have a ramp or can get access under the vehicle, otherwise it would of been a fun and inexpensive DIY experience. So just to let you guys know: it's not an easy job if you don't have access underneath the vehicle, or hoist the vehicle up.
...oh, if you're using cheap tools, you can fuggedaboudit!
