A couple of months ago, my 01 Protege began hesitating and the engine light was flashing. I drove the car for a number of hours afterwards and got the problem again. Mechanic said it had a Cylinder 2 misfire code and replaced plugs. Days later, same problem, but now registering as Random Misfire. One mechanic said the coilpacks should be replaced and another said that coilpacks are not the issue, but he couldn't figure out what the problem was.
So, I tried a couple things myself and have the following observations:
1. When it hesitates, stepping on the gas pedal has little or no effect - it just feels like it's stuck for a few seconds and then it kicks back in
2. The problem seems to stop when Pennzoil Gas Treatment is added to the tank and reoccurs on the next fill up without treatment
3. Hesitation tends to happen more when moving up or down hills
4. On at least one occurrence, a large white puff was emitted from the tailpipe (it was dark, so I didn't see it clearly). It occurred while I was travelling up a steep hill and threw the car back in 4th.
When I first saw the big white puff, I thought I'd blown a head gasket, but this isn't the case. Would this have been unburned fuel vapor? I'm thinking a fuel flush and injector cleaner as the next steps. Has anyone else experienced these symptoms and are there any recommendations out there on what to do??
