W Wwing49 Member : '03 MP5 Nov 3, 2004 #1 Im actually at 23,000 and was wondering what i should get checked/cleaned. Id rather stay away from the dealer b/c of the header.
M Mike R Member Contributor Nov 3, 2004 #2 Check the owners manual. Everything is listed. 90% of the stuff you can do yourself. the other 10% really doesn't matter.
P Protege52003 Member Contributor : '08 Jetta; '10 Wrangler Unlimited Nov 3, 2004 #3 oil change if due, clean or change filter of needed and check fluids????? check out manual as said before.....30k requires a little more fluid changes.
