2 Questions- Electric + Body
sed02010
1999 Mazda Protege LX 5spd
So I've almost fully restored my 98 protege back from the neglecting hells of the previous owner- I only have 2 things left to do that I need some help with.
The right side rear power lock doesn't work- it just makes a loud noise when I try to lock/unlock using the switch. I took the door panel off, but I'm not familiar with the electric lock systems and I'm not sure if I'd be able to fix it myself or if I should take it somewhere.
Also, does anyone know where I can get a driver's side front fender that's already painted black mica? I couldn't find anything at my local junkyards. Thanks.
as far as door lock goes, I think your lock/unlock actuator is shot. Most likely needs a replacement.
as far as parts go, you might want to contact Captain KPM P5 on these forums...he's the owner of www.protegegarage.com and might be able to help you out.
