2 cylinders not firing below 3k rpms
TDRMP3
Mazda Protege MP3
ok my 2 cylinders not firing are 1 and 3 *the ones with plug wires on them*... before you ask yes i have tried different wires and different coil packs.. i even switched the coil packs to these cylinders and the only cylinders that were firing where cylinders 2 and 4 *which means my plug wires work as well as my coil packs*
now if i rev the motor to 3k rpms it smooths out all 4 cylinders are firing *and if i pull the wires while revving u can tell the difference*...
now i tried different injectors blew out the fuel rail and checked the FPR on the rail and all checked out.. if anyone has any ideas lmk also have tried a different ECU check timing and blah blah blah....
