2.0 bp start up and build pics in AWD MX3
josh95mx
so i have the engine together and in the car. still need to finnish the exhaust, but you will get the idea. i will have some real vid footage here in a few weeks. but for now this will have to work.
the Cams are so big the thing wont hardly idle. i will get the stand alone in soon, hopefully by the end of sept. im just going to tune it with the VAF and FPR untill i get the SDS system in.
here is a brake down of what i have put in it so far.
Block:
-Carillo rods
-micropollished crank
-weisco pistons
-over bore to 1995cc
-resurfaced
-entire rotating assembly balanced, with flywheel and harmonic balancer
-mazda speed oil pump
-GTR Water pump
Head:
-1mm over bore on intake and exhaust valves
-ss and backcut
-custom length valves to go with the cams
-Stage 5 E production racing cams 286 duration, and a whopping 11.38mm lift
-head was ported to gasket before i got it, so no need.
-Eibach EVS valve springs
-Jun performance cam gears
Turbo stuff:
-GTR Intake mani untill i get my custom mani finnished
-Maita custom tubular manafold
-Subi flanges
-Subi VF12
-Greddy RS BOV
-2 1/4" IC piping
-3" Cork Sport FMIC
-custom 3" Down pipe to a cut off then 2.5" back
im probably forgetting something but heres the clip!
http://video.google.com/videoplay?docid=-2411865133318102561
oh yah the exhaust is wide open down pipe too.
moding the 99' Miata MS plate
The head
The FMIC
and the finnished product
sounds very nice. someone needs to make a bp conversion kit for a 3rd gen protege.. :)
Impressive work.
However, have you've bored the engine, alone, to 1995cc or are you increasing the stroke as well? The BP's cylinder walls are dangerously thin being bored to such a high displacment.
1995 is well within tolerances. its what my toda build was, with just overbore. its what the toda race engine has to
well the engine is new and i dont want to get on it too hard yet. but it hits 10 psi at 2K rpms. and the cams take it all the way to redline. i thought this turbo would be plenty big, but i might have to go bigger. we will see. 1995cc is about as big as one would want to go on a bore increase. i still have a bit to do. i should be able to hit 300 to 350 to the wheels with this turbo. i will keep everyone posted
This is what happens when one falls off the end of the world. 4 years without an update I suck! I will get one posted tonight
Currently the car is down as I am redoing almost everything minus the engine. Installing a SDS stand alone and re-fabricating the way I installed the rear end. Tones of additions, and rare Euro and Japan parts that I have collected for it. Shouldn't be much longer until I have it on the road again.
Few pictures of the under carriage
This is how she sits right now with the mock up front lip side skirts and rear spoiler
Some new additions that are going on the car
Factory MOMO
The new suspension: Koni Red inserts, custom rate GC's and H&R preload springs and cusco camber plates front and rear
The new Turbo set up is a Subi style 16G with a 3" DP and a 2" separate wast gate
The rear end
Some MAZDASPEED LSD action
after some sanding and a little primer
and some paint...
