18x8.5 +43 on Mazdaspeed3?
It'll rub because the stock MS3 wheels are 18x7 with +52 offset. Pushing a wheel out 9mm and being 1.5" wider will have it stick out. Therefore, rubbing especially in the rear. People running the RX-8 wheels which are +50 offset and are 18x8 usually run 225/40's and don't rub when they are slammed. I've also see +48 offset with the same 18x8 and 225/40's work but with rolled fenders.
Just roll the fenders. People seem so afraid to run low offset wheels.
And you know this how?!
Just from doing the math pretty much like Cno said. I have seen alot of different wheel sizes and offsets on this car from this and other forums so I have a good idea of what will or will not work.
But prove me wrong, rolling the rears would help you try and fit these wheels.
Its been done dude. I was just actually interested in seeing pics. Theres no sense coming in here and just saying, "oh it wont work."
Anything will work if you've got the time, tools and money. I believe somewhere on here, someone ran/is running 255/35/18's but I forgot the width and offset were. He basically grinded the inside rear fender a lot and rolled it. And also, stiffer suspension wouldn't let you rub as much either.
I completely agree with you here, people seem scared of rolling the fenders. If your going to upgrade your wheels, why not go a little bit wider as well!
even you you roll the he will rub on any bump thats why i said coil over so he cann adjust stiffnes and dont rub
Cobb ran some 18x8.5 with a 52mm offset that I believe they put 255s onto.
