100k recommended maintenance
ImANerdyPunk
'06 Mazda 3s
I have a 2000 LX with a 1.6L engine and I'm about to hit the 100,000 mile mark. I've already been told to look at the timing belt and water pump. Anyone have any other maintenance recommendations?
look at the other belts as well....and change your spark plugs if you haven't done it yet!....and if you have a manual transmission, it might be time ot check the clutch also...i just changed mine (115000miles on my 1.6)
my original clutch lasted until 184,000 miles b/f is started slipping. original timing belt also, which i would deff recomend that you replace that soon.
if it's an automatic, time for a fluid and filter change. 100K is a good time to do a coolant flush too. Probally a battery check is in order as well. Check your rear drum shoes too, if they've never been replaced they're defentaly due.
