ScorpioGTX1
- 2012 Mazda 2 GS M/T
So I've noticed that when I try to do a 1-2 shift rather quickly around 3k rpm, sometimes the gears will grind and the transmission will refuse to go into gear. At first I thought I was accidentally lifting the clutch too early, but it happened again today and I was absolutely certain that my clutch was 100% in. I have to shift to neutral and declutch before it will work again. I ALWAYS rev match downshift and the car only has 12k km on it, so I doubt the synchros are worn, I'm guessing that I'm just asking too much of them too quickly. I've had it happen a couple times on the 4-5 shift, but never on any other gear.
This really doesn't happen often, and if I really focus on proper engagement it never happens. Just curious if anyone else has had this happen when slamming it into second a little too carelessly. I hope nothing's fracked in my trans.
