08 MS3 dynoed on 10/28/08
08.5 with 4300 as of 11/24
as of right now
injen cai(possibly switching to the nano in a month or so)
forge bpv(blue 1 shim)
exhaust depot fmic
(put down 280/304 on a dynojet with mod above)
turbo xs dp/rp combo(and have driven the car for about 300 miles and no cel yet)
pg manifold
coming before christmas
high flow pumps internals
one step colder plugs
darkstar's passenger mount
inlet pipe
standback with pnp(which will be set at most likely 19psi with a conservitive map at 14psi)
full throttle flash
This is my breakdown and if i'm not having any problems i will be stopping there with my mods and just have fun with the standback everyonce in awhile.
Does anyone know of a good place to dyno the car in Central Jersey? I wonder how much I would put out at this point.
as of right now
exhaust depot fmic
pg manifold
inlet pipe
full throttle flash
Are you going to dyno it again to see what the dp/rp combo gave you over your first dyno ? We need someone to get some accurate numbers for bolt-ons and before & after tunes.
i'm planning on dynoing again this coming week depending on how my professors are since finals are coming up. i'm hopefully gonna have the inlet pipe, passenger mount, spark plugs and high flow pump installed. then when i get the tune i'm gonna do one with the standback not plugged in but will have the full throttle map. then the other 2 will be my agressive tune.
here is a lil update on my project
high flow pumps internals-gonna wait on this til i see what my fuel pump is like and ill probably hold off on this one for awhile.
one step colder plugs-ordered but on back order til next week
darkstar's passenger mount-supposed to be shipped by now
inlet pipe-been shipped
standback with pnp(which will be set at most likely 19psi with a conservitive map at 14psi) is being shipped
full throttle flash-sent the ecu off today
i also decided to order the trz transmission mount so ill be getting that here soon also.
i'm gonna be tuning the car next week on days it's nice and the following week will be when i get dynoed again. sorry i won't be able to get a dyno run in before all this. finals are kickin my ass.
