H HBrown Member : 03 mazdaspeed protege Nov 7, 2014 #1 I have a mazda protege and it runs good pulls hard when cold, but when it worms up it doesn't like to pull under boost. Holds 6psi all day but when worm if u move to positive pressure its like the boost is there just no go?
J junya1985 Fixed 3rd Gear : Mazda Speed Protege 03.5 Nov 7, 2014 #2 sounds like possible leak or wastegate problem
H HBrown Member : 03 mazdaspeed protege Nov 7, 2014 #3 Lol does that wastgate open under vacuum? Because the wastgate holds no vacuum.
B Blake D Member : 2003.5 Mazdaspeed Protege Nov 9, 2014 #4 is the car stock? if so then what you may be experiencing is just the nature of a msp.
H HBrown Member : 03 mazdaspeed protege Nov 9, 2014 #5 Ya its stock so a stand alone should fix that?
H HBrown Member : 03 mazdaspeed protege Nov 9, 2014 #6 Ya its stock a stand alone should fix that then right?
B brandontt26 Member Contributor : Mazdaspeed Protege 2003.5 Nov 9, 2014 #7 Yeah sounds like your experiencing the MSP stock tune.. Big prob is they run really rich so its almost like the engine is bogging out.
H HBrown Member : 03 mazdaspeed protege Nov 9, 2014 #8 Thank you all for ur help I will just have to wait for my megasquirt.
