ARP Hardware
I have speced main bearing studs as well:
Main Bearing Studs
Kit Part No. 203-5403
Design for Toyota 4AGE motor. Kit includes 10 studs, washers and nuts. Studs are 3.4" long with inch thread on either end. Block thread is 10mm - 1.25 pitch.
$94.48
Head Studs
5.100 11mm 1.5 Thread Pitch Stud
Stud No. - AM5.10L
$5.16
12pt Nut
Nut No. - 300-8344
$5.43
.120 Washer
Washer No. - 200-8519
$1.37
With a quantity of 10 of each that comes to $119.60.
Enjoy,
Dang, I can't find those head studs on their site. Did they change the part numbers around?
The head studs will not be on there catalog. They are individual studs that will have to be ordered that way. Oh yeah just to let you know there is a slight change to the part number. The updated number is: AM5.100-1LB. You will have to call ARP directly or have the distributor you are going through to call them to make the order for the studs. Hope this helps......
Dave
No problem. I just like helping out! :D
Dave
bump.. and a few Q's
Ok if you have pauter rods, then does the arp hardware (bearing studs) come with them? I was under the impression that they did.
Also, what is the exact part number for our studs and nuts needed for our head? Also are these studs "cut" or "uncut"?
All i need i believe is the arp head studs as well as the nuts. What are the part numbers for our cars?
Thanks abunch.
-B
Thanks abunch.
-B
Don't get main bearing studs mixed up with rod bearing studs (Pauters come with these).
What is uncut?
The part numbers are listed in the first post:
Head Studs
5.100 10mm 1.5 Pitch Stud
Stud No. - AM5.100-1LB (new part number)
$5.16
12pt Nut
Nut No. - 300-8344
$5.43
.120 Washer
$1.37
Wow, I just got an email back from ARP and the prices are still the same one year later!
Main Bearing Studs
$94.48
Head Studs
Stud No. - AM5.10L
$5.16
12pt Nut
Nut No. - 300-8344
$5.43
.120 Washer
$1.37
Enjoy,
bump....
does anyone know where I can get these ASAP? I have an opportunity (bay time) with an installer to build up a used engine i have just purchased.
I have sourced the washer and nuts..but the studs are the problem.
The local dealer in Toronto does not have them...and will take a long time to source.
Any help would be tremendous.
Try contacting them via there web site and ask them if they have a dealer near you. Or maybe you can pick them up directly from them. www.arp-bolts.com I ordered my bolts locally but the head studs they will have to call ARP to get them cause they are individual peices. I just ordered mine last week Monday and got them in last week Friday! They had the head studs in stock! Well the key word is HAD. I don't know if they still have them in stock but I wouldn't doubt it!
Dave
I just ordered the stuff direct from ARP. I will have new PNs and for everyone...and a cheaper price once I get my invoice.
