2013~2016 CX-5 Wiring Issues, Help!
Please, I need help! Having issues with some wiring on my 2016 CX-5 GS. Wiring diagrams aren’t showing what I need (Or I can’t read them anymore).
I have found a plug but don’t know what wires are supposed to go where, colours aren’t matching up. Literally if I just had a photo of one intact I could fix it.
Where is the plug at? It looks like the front end below the passenger side fog light assembly. You think something got pulled off when the impact occurred?
Sorry, should have had that detail in there. Yes behind the passenger headlight assembly. The connections from the headlight combine into this connector on the front harness
It is actually a part of the wiring harness, thankfully there’s no add ons by previous owners.
But they don't look right. 😳 The grey piece usually connects to a similar piece with two or three prongs. Here you have two skinny wires with spades and stripped ends. It looks like a DIY fix to connect to the loose wires from the harness. Anything not working?
I know someone who can decipher this though. Hello @AL Cx5 can you check this out please? 😄
