Fluid changes
Just bought a new 25. Reading the manual I see they claim Trans fluid “periodic replacement unnecessary”? Transfer case and rear differential changed only if submerged?!! Crazy
And the diff and transfer case hold tiny amounts .37 qts and .48qts. No way Im not changing.
Planning on drain and fill the trans at 30k, and drain and replace the diff and transfer then as well, and every 30k afterwards.
Good enough?
Also why do they call it a transfer case? seems like 4x4 terminology.
Sounds like a good strategy. Mazda says those fluids are lifetime but they don't say how they define lifetime. My guess lifetime to them is till the warranty ends.
I guess by transfer case they're talking about transferring power to all the wheels that need it when slipping is detected.
Absolutely right - lifetime means the period under warranty
Thanks. Just ordered a qt of mazda sg1 for either my first change or to top off if low from factory. Need to get 15 years out of this suv.
You shouldn't have a problem getting 15 yrs. I'm hitting 11 yrs (Purchased Apr 2015) on my 16 Touring and it still runs/feels new. Zero problems.
Our two Mazda's have been the most reliable, least expensive vehicles we've ever owned and we've owned a lot.
Good to hear. The 2.5 was a big motivator. Have a 2014 5 speed focus, its 2.0 gdi has a lot in common with this engine, and its been trouble free at 105k. And the 2.5 is laid out pretty much the same. Same gdi noisy idle! And our 2006 2.0 focus still runs like new at 170k, also never a issue. Great motors
Good enough?
Good plan. I just hit 150k on my 2014 and servicing the transmission, rear differential, and transfer case are all on the list. Did the spark plugs today.
There is a transfer case if its an AWD model.
April of this year will mark year 13 for mine since owning it (purchased April 20, 2013), but with a door sticker of 01/2013, the car itself hit 13 last month. The vehicle has been fantastic. Aside from some early model issues with lock actuators, a shifter switch (that was revised in later models), and a leaking belt tensioner, everything else on the vehicle has been maintenance really. The front suspension work I did a couple years ago (struts, lower control arms, end links) was a bit pricey but to be expected at that age / mileage. I need to do the rear shocks this year.
Honestly I want it to be a 20+ year vehicle..
I had a 2006 Focus ZX-3 with a 5 speed manual. Loved the car. It got done in by a deer. When the car was totaled in 2013, I had 176,000 miles on it. The car was bought new. The engine in those cars are Mazda powerplants. I had one major issue with it that was covered under the Ford extended warranty. It took the dealer over a month and two attempts to fix the problem. I forget at what mileage this happened but I think it was under 50k miles. The fist mechanic misdiagnosed the problem even though I told them it's a valve tick. So he did repairs that didn't fix the problem. Got the car back and the valve tick was still there. To confirm I wasn't crazy, I took my car to a friend who is an ASE Master Tech. He also confirmed it was a valve tick. I took the car back to the dealer. The service writer came out with the mechanic and I demonstrated the problem. The mechanic huffed and said he can't do anything to fix it as he said the followers are mechanical and can't be adjusted. Then he stormed off. My service writer and I just stared at each other in shock. The service writer then said, I'm putting a different mechanic onto this job.
So what ended up happening was the car was at the dealer for over a month. The mechanic had to consult with Ford Tech Support for the course of action. The repairs ended up being replacing the exhaust cam along with the followers. After that repair, the car was solid till the deer incident.
"Lifetime" does not mean "during the warranty period"... So tired of that Conspiracy theory.
Every company says this today...it does not mean "through the warranty'...it doesn't mean "up to 100K".
It means A LONG TIME.
Can you imagine if Mazda's trans only lasted to 50K miles? Probably wouldn't have the reputation they've earned today...
To be clear, I don't believe in Lifetime ANY fluid. But I do believe in long lasting fluid. I know a guy with 250KM's on his original Volvo tranny fluid. I'm not suggesting anyone not swap fluids AT ALL. Only that "Lifetime" can mean a REALLY long time. I haven't done my CX5 yet. Aiming for right around 100K. She still runs as good as she did day 1. Also not suggesting anyone do that. It's what I'm comfortable with.
Agreed. The reality is that the transmission and differentials are designed to operate normally well past the warranty period. How long exactly is anyone's guess - but driving habits and environmental factors play a huge part. A car that has an easy life (well-maintained, no winters, easy highway drives by a driver who occasionally pushes the car at higher speeds), will likely be fine on the original drivetrain fluids, compared to someone who tows a lot, drives in slippery conditions often, and accelerates aggressively from one stoplight to the next.
I use this example a lot - my wife's Civic is 20 years old and has 220k kms (135k mi) on it. Mileage isn't super high for the year but she's never been "nice" to the car - slams it into gear, doesn't let it get up to operating temp during short drives, and she's never changed the transmission fluid. It still shifts perfectly fine, no slipping or hesitation. But she also doesn't tow anything, she knows how to drive in winter to avoid spinning her tires, and she doesn't gun it from light to light.
Just curious.....what viscosity engine oil do you use?
Average lifespan of a vehicle is 10-12 years and 150,000 miles.
Since most vehicles will make it to 150k, I will assume that’s what they mean by “lifetime”
Come on now...we all know what the bean counters mean by lifetime. It is not a conspiracy. The service department welcomes major repairs from those who don't do regular maintenance...
0w20 on the 16 NA. All oil changes done at the dealer. Whatever they use.
I think the Turbo takes 5w20 or maybe it's 5w30. Too lazy to go out and lift the hood to see what the oil cap says.
