Get firmer shifts with FN4A-EL automatic transmission (theory)
The main flaw of the automatic that causes premature failure of the band and 3-4 friction pack is low line pressure. under heavy acceleration, the slip time of the frictions simply produces too much heat for the relatively low amount of frictions and under-cooled transmission fluid to absorb.
With a simple 5 cent resistor and an auxiliary transmission cooler, you can get the benefits of raising line pressure and reduced heat throughout the rev range. The fn4a-el transmission uses a variable force solenoid to control line pressure. the ecu changes the amount of current sent to the solenoid to either lower or raise the pressure. less current=more pressure. the stock range is 2.4-7.3 ohms. By adding a 1-2 ohm resistor depending on how you want shift feel, it will artificially lower the current sent from the ecu and raise line pressure. the control wire for the solenoid that needs to be cut and the resistor installed is the black one coming from the transmission valve body.
I don't believe that this will cause the transmission light to turn on, as the code for the pressure control solenoid is only activated if it is stuck at a certain voltage after engine start.
I will be testing my theory in the next week or so.
Did you ever test this theory? I’m putting a spare auto back together and this would be worth doing while I’m in here.
Now we're talking good mods. 👍
Thanks for this information and like you fully understand the benefits of higher line pressure and preservation of the transmission.
You'd mentioned a 1 or 2 ohm resistor value but didn't say what wattage resistor to use.
As an electronic tech of 40 years I'd guess a simple 2 watt resistor would be feasible for this.
Personally I'll be trying the 2 ohm in the very near future.
When I had a z24 Cavalier with the 4t40e transmission there was an inline shift kit that would let you adjust line pressure and torque convertor lockup.
The 4t40 transmissions were not renowned for their longevity due to the same line pressure issues and premature wear on the bands.
I'd set mine for full torque converter lockup and 75% line pressure and that transmission lasted the life of the car.
235,000 miles, 3 years drag racing, and shifts that sounded like quick manual shifts when full throttle.
Best device ever made for a transmission.
Anything to save these transmissions is worth the effort.
With 96,000 on my '02 Protege I want it to last as long as I do. 😁
Good to see some activity here with the Protege community. 🙂
I doubt the solenoid would use any more than 10 watts. Get a nice ceramic resistor so it can dissipate heat better. Or even one designed for led blinker conversions with cooling fins
If you want to go all out, lentech still can make valve bodies for our cars. I have one and it is awesome
I was actaully talking with Lentech on Friday! A lot of good and fun info from them.
We’re trying to see about a torque converter for upgrade.
Apparently the Alto Reds are absolute trash haha
Awesome. I heard that they used a stator plate from a different vehicle in the torque converter. Keep me updated because I would totally be down to buy one
