Thanks. I'm in NZ so happy to lose the Japanese stations, and hopefully be able to get the NZ ones!My understanding is that you can. Keep in mind you will lose Japanese radio stations if you choose to go that route (due to frequency differences).
I'll let you know soon. I just bought a 2019cx-8 JDM import that has had its firmware changed so the dash reads in english. (The infotainment language is just a setting in the infotainment menus...)Does anyone know if you can change region by updating the OS? I have a Japanese car but would like to update to AU/NZ version of the OS.
Can I overwrite / install the different region.
Current is:
70.00.110 JP M
Following the recent update to firmware version 74.00.324A EU N, I am pleased to report a significant improvement in system performance.Thank you, @Candurin.
I've just upgraded to the latest version and am hopeful that the previous bugs and glitches will no longer occur, or at least happen less frequently.
That's usually an indication of a bad/incompatible USB drive. Is it less than 16gb and formatted to FAT32? Make sure you are following the directions for the more recent firmware (.UP files versus the older failsafe versions).Soo,today i was trying to update from 70.xx.xxx to 74.00.324A EU N and my MZD says there is no update file. I have checked the files with Md5 sha and was everything o.k.. Now the 10 points question is why?I have followed the steps exactly.Can I try now to start engine and drive?becouse tomorrow I must go to work)
Don’t thank me until after we get you updatedI have downloaded this file and I will try again tomorrow with another USB stick . Anyway ,from the file you have sent I did a check on what I have done and everything was ok from first step to 17. USB I used is 4Gb, as I already said ,I will try again with another one. Thank you once again for your support @Candurin.
Ok,I have done it.Can I say thank you now ?Don’t thank me until after we get you updated![]()
I have a 2019 CX5, and want to perform software update purely for the bug fixes. I don't intend to install the wireless carplay module, will these files still work for this use case? Are there any differences in the installation procedure?
Thanks to @Fitzgibbon, I can now provide FW for 7th generation systems (2021-current) as well (ONLY North America for now, until I can spend more time with this).
