Mazda Connect Firmware 74.00.230A (now .324A)
Status
Not open for further replies.
Good to hear and funny you mention that. Ash8 is super awesome and got me going with the firmware, but on another note while I was trying to backup the navigation SD card it was painfully slow and kept failing.
I used win32diskimager to make a backup image of the card and luckily it was able to read it and make a block level backup. I restored that image onto a newer SD card and it's night and day difference now with speed and loading. So maybe that will fix some other quirks.
@ClssicCaleb i will give a try using the same tool as you, win32diskimager.
I have not been able to create a backup from mine, BHP166EZ1D
Please note the OP has directly copied my files in his first post, but I can not amend it.
There has been a change in what Version Numbers to now Install and this depends on what Version is currently running in your Mazda today.
Install Procedure...
(All Mazda Models already on Stage 2 .up firmware in use).
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW
55.00.600 NA N for North America, or,
56.00.000 EU N or 4A N for Europe/UK , or Australia, Asia, NZ, Oceania Middle East.
LIKE 31.00.100 or 41.00.000 or 55.00.000 (NA N) or 56.00.000A (EU N or 4A N).
THEN YOU MUST UPDATE with Version Number 70.00.100A First!.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
70.00.100A-FAILSAFE.UP (First)
Then next Install (one after the other do not remove the USB Flash Drive).
70.00.100A-REINSTALL.UP (Last)
Warning...!!!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL use YOUR ''CONNECT'' in CAR FOR A FEW MINUTES, THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION TO INSTALL.
Next you MUST do final and last below.....
Your FINAL Install Procedure is now Only a 1 (one) File Installation...
(All Mazda Models with .up Firmware use)
IF YOUR MAZDA HAS .up FIRMWARE VERSION ON or ABOVE
55.00.650A
(NA N) or the 56.00.100A (EU N or 4A N) or 58.00.310A
or Any 59.00.502A or 59.00.650A,
or Any 70's Firmware like 70.00.021A, 70.00.100A or 70.00.110 or
70.00.150A or 70.00.335C or 70.00.367A or 74.00.230A or 74.00.311A
THEN YES YOU CAN UPDATE Directly to 74.00.324A for LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY,
MUST USE EITHER ONE of...
NA N_74.00.324A-UPDATE.UP (North America ONLY)
or
EU N_74.00.324A -UPDATE.UP (Europe/UK)
or
4A N_74.00.311A-UPDATE.UP (ADR, AU. NZ, ME, Asia) (74.00.324A 4A N (ADR) is not yet available)
THIS IS THE LATEST GENUINE FIRMWARE CURRENTLY AVAILABLE
FROM MAZDA JAPAN As Of December 30th, 2022.
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...None, DO NOT ASK.
YOU MUST PURCHASE and INSTALL the TWO GENUINE MAZDA PARTS LAST.
DO NOT INSTALL THESE NEW PARTS FIRST or BEFORE ANY 70s FIRMWARE OTHERWISE YOU WILL HAVE TO REMOVE THE NEW PARTS RE-INSTALL THE OLD PARTS AND THEN START AGAIN.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
Hi @ASH8, currently i'm using v70 version. For me in asian, should we wait for 324A or just update with 311A version? thanks!
Hi everyone,
I recently got myself a Mazda CX-5 2017 and I would like to update the firmware. Currently, I have version 70.00.367 NA. I would appreciate if anyone could share the link with me.
Best.
Hi all, just got my first cx-5 (2016). Where are you getting the carplay kits? i've seen them on amazon, but i don't know if they're mazda genuine parts.
I don't think you can buy the genuine Mazda parts on Amazon. Probably eBay. Of course you can order from any number of Mazda dealers online.
Realmazdaparts.com, etc. mazdagear.com
I just got mine off Amazon, but it's not OEM.
I am so glad that I did not upgrade beyond version v70
because of the dpi setting in v70 I am getting vertical bar now in the new android auto UI (coolwalk) while if I had upgraded, the dpi will force android auto to use the same horizontal bar
Likewise to the recent comments above! I would love the latest NA region firmware if someone has the chance to PM me it would be much much appreciated!
Just joined the forum. My daughter has a 2016 CX5. She has dealt with the rebooting in cold issue for years and I just learned about it when she came home in December. I have ordered a new nav card for her to hopefully fix that issue.
I have also ordered a carplay retrofit to install for her birthday when she comes home for break next week. When she gets home I'll see what the current firmware is. Thanks in advance.
My daughter just texted a picture of her settings.
OS Version is 59.00.441 NA N
Music Database Version is 00.07.000
Fail-Safe Version is 59.00.441
Thanks
Status
