Howdy! New to the forum. '02 p5, not mine, but my daughter's. I just get to fix it! Had several leaks that needed addressing. Spent the whole of a Saturday figuring them out. Symptoms: soaked passenger front foot well, mold on mat. Soaked passenger back carpet, mold on mat and seat. Half inch standing water in spare tire well. 3" standing water in passenger side wheel well. 1" standing water in driver side wheel well.
No water marks on ceiling or around windows. Checked for clogs in sunroof, none but blew them out anyways!
Knew the leak in front was either from under dash or window. Double checked all seals and noticed an oddity half way round the window. Rubber seal had been unseated from window.... definitely enough to soak the floor. Pushed and reseated, pulled up carpet and stuffed towels to stop up water.
Back floor and seat: after much time(and water) found that where the operational window meets the stationary wing there's the trim that runs down into the door. Normally water runs out thru the weep holes. In this case it was running out thru the bottom of the door panel and onto the carpet....soaking both the carpet and seat. I took the panel off and saw the plastic membrane had come off (sealant failed). Water was filling up the plastic and pulled the bottom of it lose and caused it to run into the car. Resealed and put the panel on.
Trunk:
that was a mystery. I dried all the areas. But that one side well keeps getting water. I'm in Washington state....lots of rain this winter. I think I've narrowed it to behind the bumper. Since p5 wraps it's more like the quarter panel.
Anyone ever take that off? Fairly straightforward? I'mma fairly handy gal, but hate to get in over my head! Sorry it was long...
Also... y'all know there's little rubber plugs in those wells? No need to drill. Pop it out, drain and replace.
