Hi,
I have been trying to hardwire a dash cam into a cx-5 GT 2021. However, the driver side fuse panel has Low Profile Mini Fuses that sit in a recessed fuse box. I have tried 5 different add-a-circuits and all of them don't fit snug / tight. They are loose so much that a simple bump will make it fly out. I tried both mini fuse taps and mini low profile fuse taps. None of them sit well or tight. Extremely loose.
Any of you found one that works?
Here is the ones I tried thus far and all don't work at all:
https://www.amazon.com (commissions earned)
I also tried Bussmann Low Profile ATP LP taps. Garbage.
Thank you
Thank you
