Actually, I didn’t say anything about an mp3, a thumb drive, or a CD. I’m referring to an iPhone streaming Amazon Music, or playing from iTunes maybe, either through BT or the USB connection. The USB connection does sound better, it’s just not a huge deal to me. However, I appreciate the diagnosis, it will save me a trip to the audiologist.USB and Bluetooth are simply ways to deliver a music file.
Now, that said, whatever you do, don't ever use an mp3 file for anything. There was a time and a place 25 years ago when mp3 sorta kinda made sense, back when we had 56kbps dial up modems and 700 megabyte CD-R's, because thumb drives didn't exist yet. But dial up modems and CD-R's have died and been surpassed, and mp3 should have died along with them. With 100Mpbs internet speeds and thumbdrives the size of a dime that can hold 512 gigabytes of data, you cannot come up with a single valid reason to still be listening to horrific mp3's in the 21st Century. Load up a bunch of wav or flac files on a thumbdrive, and listen away!
Now, notice I said use USB. Notice I didn't say Bluetooth. Why? Because the theoretical maximum file transfer speed of one very specific high end and expensive piece of Sony Bluetooth hardware is 990kbps. For standard Bluetooth that most people think of, like a phone to a car stereo, the maximum theoretical limit is 576kbps. In real world, it often dips down to 256kbps, or even lower. Compare that to the sustained bitrate of a regular old CD at 1,411.2kbps. Surely you can see that there's something major lost in translation there. When you play a wav or flac file off of a thumbdrive, you are playing the exact same signal that is contained on that 1,411.2kbps file that's on a CD. There is no bluetooth in existence that can handle a the unaltered signal of a real CD. The technology simply doesn't exist, even with the high end Sony stuff.
If you say that you can't tell the difference between listening to an mp3 via bluetooth vs a real CD, then you're stone deaf, have an utterly garbage stereo, or both.
Yeah, this is the first time I’ve tried any of the streaming services. I usually listen to podcasts or audio books these days, and have just recently wanted to listen to a little music. In search of some variety beyond my own music library, I tried Amazon. The quality is terrible. Even I noticed that. It is somewhat better with the USB, so I’ve been using that. It’s all pretty good compared to BT streaming into my motorcycle helmet speakers going down the road at 65, so I’m pretty easy to please.Streaming, except for Tidal or Amazon HD, is even worse than mp3. So right back to what I said: avoid bluetooth, use USB.
Just use MP3 encoded at 256, or 320kbps. In the CX-5, you will not be able to differentiate between CD quality and higher bit rate MP3. The audio system in the CX-5 is the weak link here.Yeah, this is the first time I’ve tried any of the streaming services. I usually listen to podcasts or audio books these days, and have just recently wanted to listen to a little music. In search of some variety beyond my own music library, I tried Amazon. The quality is terrible. Even I noticed that. It is somewhat better with the USB, so I’ve been using that. It’s all pretty good compared to BT streaming into my motorcycle helmet speakers going down the road at 65, so I’m pretty easy to please.
I definitely disagree. Right this second, I have a very mildly upgraded stereo, a Kenwood DDX8905S and a pair of $45 Rockford Fosgate Prime 6.5's in the doors. No amp, stock speakers in the back doors.Just use MP3 encoded at 256, or 320kbps. In the CX-5, you will not be able to differentiate between CD quality and higher bit rate MP3. The audio system in the CX-5 is the weak link here.
I'm not sure how you can disagree, since you are not running a factory setup. You clearly felt the need to upgrade, so there is no comparison.I definitely disagree. Right this second, I have a very mildly upgraded stereo, a Kenwood DDX8905S and a pair of $45 Rockford Fosgate Prime 6.5's in the doors. No amp, stock speakers in the back doors.
The difference between mp3 and flac is absolutely obvious.
I'll soon be installing Linear Power amps and component speakers though. That's when things are really going to start getting good.
The only way your CD sounded better, is if you had a poor quality MP3 master, or your audio settings were different between the two sources. There is nothing terrific about the factory sound system in the CX-5. It is adequate, at best. Similar to a Blose cube speaker set-up.The reason I wanted to upgrade is, the factory unit doesn't play flac or wav files. Other than that, I would have kept it, because the CD player sounded terrific even with the factory speakers. Way better than playing any mp3. I went ahead with that particular Kenwood I got because it also had Android Auto, which is great for Waze integration, it uses the iDataLink Maestro RR which gives me real gauges, plus it has HDRadio built in. If I was going to spend money to get a new stereo, I was going to get one that had everything.
>for the audio file format he is using
Which brings us all the way back around to my first comment on this post: mp3 should have died in the 90's. Like I said earlier, there is not one single legitimate excuse to keep using that lousy file format 2 decades into the 21st Century.
Should have died in the '90's? That's a ridiculous statement, as is your next. The "excuse" to keep using it has to do with acceptance. Every vehicle manufacture supports it, unlike FLAC, which is spotty at best. When we were looking for a new vehicle at the end of 2018, most of the vehicles that supported FLAC, couldn't play high res files, only 16 bit, which is just CD quality. I have over 100 DVD-A's and SACD's transferred to FLAC. Many are 24-bit/192kHz.>for the audio file format he is using
I know you have, or had a Lexus, since you are also on that forum. On my Mark Levinson there is a somewhat noticeable difference between Bluetooth MP3 and USB MP3. Bluetooth is slightly flatter sounding. In the CX-5, I can not tell any difference. I even tried streaming Amazon HD via AA, but no audible difference. As you and I know, the stock Bose system is the limiting factor.... Does anyone else have any experience with playing mp3s via bluetooth vs USB?
