Is ALH version available (scratch)
You are very demanding ;-)
While I never sat in a 16, I find our 17 heated seats heat up quickly and work quite well. Same with the steering wheel though it is set to a timer or the temp setting as it will turn off at a certain point then cycle on and off.
If I am not mistaken, the vehicle doesn't remember it being on when you start it up unlike the seats which always are on unless you turn them off
Yes that’s right. The heated seats stay on the last setting but the steering wheel defaults to off.
More observations on the 2017 vs 2016:
The seat heaters on the 2017 work A LOT better than the 2016. They get hotter and faster heat.
The 2017 feels a little more less "sporty" than the 2016. The 2017 feels a little more disconnected, not bad, just a little less zoom zoomy vs the 2016.
I noticed the LED lights on the 2017 are different than the lights on the 2016. The 2016's seemed a little brighter but the 2017 I have doesn't have the fogs but I am sure it's more than that.
Glad about seat heaters, sad about little less zoom zoomy..what about seats themselves?
Which is a bit odd
Ahh I seeI suspect that it’s to do with testing the airbag. A load like that will give a field off.
