If the op goes to the warnings in the centre display, it will have a more detailed explanation that might explain what is upsetting it.
You would think the dealer would have done this
Just checked the warnings and it says to check that the badge emblem is clean. Once again the pdf is too large.
Mods, can we have a bit more capacity for pdf’s please?
OP said area (I assume badge as well) is clean.
(hmm)
Did he mean windscreen area? It’s behind the emblem!
Both the windshield and emblem should be checked and cleaned. I really do not understand what the service people are doing here? Of course this is the inter web So grains of salt needed.
Depends on how well they are trained...
I have a brand new 2017 CX-5 Grand Touring with stop and go cruise control. About 50% of the time I use the cruise control, I get this message: "Mazda Radar Cruise Control Disabled under 20 mph". The radar faceplate and the camera are both clean (I get a different message when they are obstructed). The dealership has checked the computer and found no errors or faults. There doesn't seem to be a pattern as to when it's disabled and when it's not, so I'm having trouble diagnosing.
The manual (page 4-126) says this message displays when there is an issue with the forward sensing camera, an issue with the stop hold control function, or the electric parking break.
Any ideas?
Hey man I think I found out why it does that. Well here is what solved exactly my problem.
My 2018 CX5 never said that till after I also got the remote start installed at dealer, but like yours it wasn’t factory Remote start. So yesterday I noticed that if I turn on the remote start get in car , drive off and then put seat belt I will get message.
But if I put my seat belt on, turn on car via push start, and drive off I don’t get the under 20mph disabled ...
That’s what solved my prob. Try it , I’m guessing it has something to do with the remote start or the installation process.
PS. I am also from Midwest. So it maybe the way they install it here.
kcin911 the same for me
After I had a remote start installed
I was receiving the same message.
now I just restart car manually and no message.
Make sure your windshield and sensor up front are clean. For the sensor I used Sonax Brilliant Shine Detailer as it is very hydrophobic and repels rain and dirt much better. I even wiped the rear camera lens with it so rain drops dont stay.
