Mazda Protege G15M-R LSD
InRex323
Mazda 323 BJ (Protege 5)
Hello, im Tobias from Switzerland,i drive a Mazda 323 BJ (Protege 5) with a G15M-R Trans. Now im looking for a Low Slip Diff.
I heard that the original Mazdaspeed LSD don`t hold out a lot of power.
Can someone help me to find a good LSD? Perhaps MFactory is good? Any experience?
Sorry for my bad english. I hope someone can halp me.
With kind regards from Switzerland, Tobias
Cheers.
When you said weld casing I was thinking the gearbox casing itself. That photo shows something (differential??) inside the gearbox.
ya that is the OEM/Factory LSD Assembly. That is the simple modification you do to make the Mazdaspeed LSD unit hold power.
Mfactory is a good choice too but will cost more.
I just got my trans back from a trans shop a couple days ago,they put in the ($700)Mfactory LSD for me for $500 labor.
I bought it over a year ago and haven't had a chance to install it until i started my engine rebuild.
Let me know if you have questions about it if you go this route,ill try and help
I should be putting the engine/trans in the next week or so if all goes well
i've been on this path for well over 2 years now and collected lots of forum posts and plan old research on how-to's
it's easier if you go in prepared brother.
Fortunately i've lived 2 blocks from work for the last few years and could do this rebuild as it came up with new problems
Thanks for your answer. Do you user some other parts in your transmission rebuild, bearings or so?
Do i need special oil?
Thanks vor the support
