Booooo CVT. No more fun if they want that way.Don't forget about the CVT trans.
Mazda should switch to that as well, for better gas mileage?
The gas is really that expensive, that we still care about the mpgs?
Sent from my XT1585 using Tapatalk
Yes, but a turbo 1.5. I think we will end up seeing lots of cars like this in the future. The issue is that they have never achieved the real world MPG that is seen in the lab.
My 2014 AWD GT get ~26.4 MPG (see fuelly data) in real world city driving. A 30% increase would be >30 MPG. That would be a game changer in my mind. The motortrend data is odd in that it is 5 MPG lower in the city and 1.2 MPH higher in the highway. The CX-5 highway MPG is completely dependent upon speed. I can get an easy 30 MPG if I keep my speed at or below 75. Above that, my mileage drops to 27-28.
yes, of course but look at the numbers it puts out. 190hp 180 torque. the torque curve is also smooth and delivery is at a low rpm for everyday and cruising speeds.
There is a good chance the 2017 will get better EPA/actual highway MPG because it is lowered. However, because 2016.5 was measured using the old EPA guidelines, the 2017 might get hit with the new guidelines (see Mazda 6 2016 vs 2017 for a case in point).
The CR-V's CVT is probably the best in the market right now (compared with other CVTs) and I think most buyers will not care. I would certainly consider vehicles with CVT, as long as they are not annoying to drive.
Mazda is now trying to get ahead in efficiency with SkyActiv 2, but that's not going to be ready for at least 2 years and might slide for even longer.
You know, why is motortrend so amazed that the CR-V went 7.5 in the 60? The CX-5 has done anywhere from 7.2 to 7.8.
well unless mazda is doing something or any tweaks to the upcoming cx5 to get better gas mileage, it will be beat by the new 17 crv.
since it is using same powertrain as the current, i dont see much improvement on the mileage for the upcoming cx5.
The current latest CX5 Rated by the Feds at 24/30/26 mpg, the CX-5 actually got 23.4/27.7/25.1 Real MPG.
as for the upcoming 17 CRV, EPA-rated fuel economy for the turbocharged CR-Vs is 27/33 mpg city/highway with all-wheel drive and 28/34 mpg with front-wheel drive. Our test vehicle was a loaded CR-V Touring AWD, so compare its 27/33 mpg EPA result with the Real MPG of 21.9 and 34.2.
(source---motortrend)
that real world highway MPG is music to my ears since i do a lot of highway driving. and all the feature set on the crv its a clear winner.
the new cx5 has its looks though, nothing can beat how the upcoming cx5 exterior design.
I wonder if Honda has done anything with their impaired AWD system? It seems to be the least capable of the current CUVs out there. That alone for my needs would exclude it for consideration.
Of course, looks is subjective and I would not call the new CR-V pretty. Honda now is in its over-styled period, though I think the new CR-V is much less so than the Civic.
From what I've read so far, Honda did an excellent job with every aspect, from much better NVH, excellent passenger and cargo volume, great engine, an improved CVT, brought back the volume button to its Andorid Auto equipped infotainment.
I suspect the new CX-5, which I consider a tad less attractive from the outside compared with previous gen, will get better highway fuel economy, mostly from being lowered. However, I don't think they'll be able to match the CR-V's fuel economy with current gen SkyActiv.
It would be my guess that the CX-5 will still be more fun to drive, but in terms of overall package, the CR-V might be a better choice.
Can you provide the BSFC/rpm chart to support this statement?
It seems lowered. Ground clearance for city folks matters little; it is the heightened stance and better visibility + ease of getting in an out that makes a huge difference. A lot of CX-5 owners will take one inch less Ground clear for an extra mpg or 2.I really hope that it's not lowerd. The 8.5" of ground clearance was a big selling point for me vs the second choice 2013 subaru impreza with 5.9".
...most likely, because it used to be probably 9 seconds.![]()
I haven't ever driven a car with a CVT, but my understanding is that they are, by their nature, annoying to drive. When I say "by their nature" I mean that they always feel different because there are no actual gear shifts, and this is what is annoying to most people.
What makes Honda's the best in the market in your opinion?
My wife had a Prius with CVT as her daily driver. Even though it is a different type of CVT, without pulleys, it was annoying to drive.
Engine droning is when the CVT keeps the engine at very high RPM while it accelerates. Not liking it is subjective mostly, though tied also to the kind of sound the engine makes at WOT. The Prius WOT sounds was pretty bad... Some people complain because they are not used to it, not because of any other reason. Even with the Prius, a typical drive does not involve many times of high RPM. On the other hand, a traditional 5AT in a Civic also makes somewhat busy sounds when you need to push it hard.
Some CVTs keep the engine at high RPM when you floor it because that's where max acceleration is. Honda and Subaru mimic gears to quell these complains, at the expense of losing some acceleration. IMHO, I'd rather accelerate more quickly when my foot is all the way down.
However, Honda CVTs are also pretty responsive, unlike the Prius, where there was a feeling of 'slippage', where the ratio slides gradually down, which provided the feel of a indirectness. In a Honda, the transmission shifts quickly, without this gradual sliding.
In normal driving, however, CVT gives a sense of smoothness that a traditional AT can never have. Especially when driving slow in a parking lot, where a traditional AT will either rev a bit high on 1st then you'd feel a little shift shock to 2nd etc.
Same is the case with 2.5T. Mass audiences don't care. Few enthusiasts do and that is what gets discussed. I think selling a production slot for 2.5T makes more sense for Mazda. If you want one, purchase a slot and take delivery in 2 months with your trim + color options.
