Bass stays in car not coming out of car: Help
aman1033
Mazda CX-5 Toruning 2013
HI
Today I installed Poinner W3003, DVC 4 ohm 2000W Sub-woofer with Mono Poinner D9601 2ohm @800w with Lc2i, Sub box is 1.5 Cu Ported
Everything is working fine, at level of 40 volume he has too much Bass in Car, but outside of car , it not enough , seems like someone listing regular audio system.
Any Suggestion?
HI
Any Suggestion?
Why would you want bass outside the vehicle?? Do you turn the car on, play music, get out and close the door to listen. Lol. Just curious. You should want the bass to stay in the car. That's a good thing. Just my 2 cents ;)
This.
Sent from the wrong side of the tracks.
Well, there are some solutions...
Seriously though, how is everyone supposed to know how cool you are with your bangin' techno beats if they can't hear your wipers/door handles/license plate/hatch rattling?
HI
Any Suggestion?
There are just no words. (hand)
Park your CX and go listen to live acoustic music at least twice a month for the next 6 months so you will know music actually sounds like. Then rip that crap out of the car and install a quality system that reproduces music that sounds like real music.
Considering the BOSE system drops off at 45Hz and won't provide the deep low bass that travels "through" walls I could see that one possibility of not waking up the neighbors. The other is the amp. Whats the RMS rating?
My single 10 located in my car's trunk powered by a 260 RMS watts mono amp has enough bass to be heard (when windows up) by the car next to me. If someone with a BOSE system wants to be heard from blocks away you merely need to replace the entire system. In this case OP should get a different head unit, two 12's in a ported box, and a 700 RMS watts mono amp. That should do the trick.
