O ogsp5 225 whp @ 8psi : 2002 p5 (MSP Powered) Jun 13, 2016 #1 Looking for the grey plastic connector to the wire loom Attachments Picture 029.webp 183.6 KB · Views: 212
J Jackie chan Member : Pro5 Jun 15, 2016 #3 Ive got one if you want to cut one of the alignment fins off your sensor. The plug is off an mpv.
O ogsp5 225 whp @ 8psi : 2002 p5 (MSP Powered) Jun 15, 2016 #4 Jackie chan said: Ive got one if you want to cut one of the alignment fins off your sensor. The plug is off an mpv. Click to expand... can you send me a picture
J Jackie chan Member : Pro5 Jun 16, 2016 #5 ogsp5 said: can you send me a picture Click to expand... Yeah, here you go. You can see the plug is symmetrical whereas with ours, the alignment slots are at different heights. Should work though. Just trim the ridge off the sensor. I also have the corresponding sensor if you want/need it.
O ogsp5 225 whp @ 8psi : 2002 p5 (MSP Powered) Jun 17, 2016 #6 I might have a line one local. If it falls apart I will get in touch with you.
