It doesn't seem like an uncommon maneuver. I've certainly been in that same situation many times.
Mazda i-Activ AWD system presentation by Engineer Dave Coleman, Part II
My only concern watching video is that I didn't use the Mazda diff oil when I recently changed them. It was noted Mazda used a special fluid for MPG but my mileage hasn't been affected.
As long as it met Mazda's stated specs, you are fine!
I remember when I had a WS.6. We put Royal Purple diff fluid in there. About 5K miles later, the pinion bearing spun while gently backing out of the drive-way. The bearings were purple/blue from heat. It was filled to the correct level, observed during tear-down. Did Royal Purple cause it? I dunno, but I never used it again!
What does a domestic car with questionable machining and assembly processes have to do with a Mazda built using modern state of the art matching equipment and assembly processes? You're over-thinking this. The failure was likely due to being shimmed sloppily or machining out of tolerance. The fact that the fluids had been changed 5,000 miles ago was likely just a coincidence.
It ran fine for around 75K miles until then, and for another 70k miles after that (sold it at 150k).
Of course, as you say, it could be a coincidence. It's a sample of one.
I don't know what that has to do with Mazda's AWD or the CX-5's handling on snow/ice.
These videos are typically invitation-only type events from what I understand for people within the company. GM does the same thing with their Corvette. The only videos I have seen leak out are lay type recordings like what we saw with this one. They contain information that will never make it into any product manual or anything of the sort, and are absolute gold for people who "want and care to know more" about a platform.Wow, listening to Dave Coleman explaining about the AWD gave me nerdgasm
Seriously, unless the competitors can showcase their innovation/design with this much research and thoughts (unlikely, as demonstrated by the Subaru and CR-V slipping back down the hill), Mazda won hand down. Dave is totally right that it's hard to prove how efficient the system is when the system itself try to prevent the symptoms before they surface.
Every little details about how they shaved the weight, how to keep oil level low while maintaining a puddle for quick start-up lubrication, how the lock-up can be controlled precisely and instantly ... I love how they studied human vs computer detection of slip and take care of the problem in the gap, balancing between car control and driver feedback.
I've only wished that the videos were recorded more professionally/better quality, hopefully Mazda will release an official recordings. These videos are way more effective at advertising their technology than any commercial ads.
For those who didn't see my earlier post about a steep ice test I performed recently:
I've found it takes some pretty extreme conditions to get my AWD CX-5 stuck but, as with any vehicle, there is always a steepness limit to what's possible. On bare pavement that limit is typically steep enough that you'll never encounter it with an AWD vehicle. But on wet ice or in sloppy snow with an ice layer underneath, you can easily encounter it, even with winter tires. If the road surface has a side slope, you will encounter it sooner.
If you ever have trouble making forward progress, I recommend stepping on the foot brake with light to moderate pressure while simultaneously easing moderately onto the throttle. I've tried this on a steep, wet ice driveway where I purposefully stopped on the steepest portion and the trick worked like magic! I've never had to use this trick in a real world situation that I didn't purposefully devise but it's there if you need it. Caution: do not drive on surfaces so steep and so slippery that the brakes cannot hold the vehicle stationary! This never ends well and once you are on such a surface it is pretty much too late to do anything about it. And please use winter rubber if you're going to be on icy hills or driving on snow/ice faster than 25 mph, even slower depending upon how slick it is.
