installed the led rear fog lights. Wired brake/running light.
great looking car Chris, do you mind sharing the specs of the wheels/tires and what kind of drop you are on?
Would you mind to tell me more on your rear fog lights mod? You may have a write-up somewhere but I'd tried the search and to go through your posts but you have too many...installed the led rear fog lights. Wired brake/running light.
Thanks for the info. I'll check these things out but it sounded like adding the rear fog is difficult to make it looks like from factory, especially the light switch! It's too bad we can't have this feature in NA version!I did not do a write up for them. I did take some pictures on the install. I do not have them on a switch since the NA versions do not have the rear fog light wiring. Each light has two wires. One ground, and a power wire for each array(top and bottom). I simply wiretapped mine into the brake and running light wires. Initially I tapped it into the blinker instead of running but changed it because I wanted to have more use out of them. I also tried to wire them as switchbacks using the circuit from a LED drl strip I got from ebay; however I could not get them to blink Nsync with the rear taillights.
https://www.ebay.com (commissions earned)
Contact the seller before buying, he is a noob at ebay so you will need to tell him which color you want (he listed them, but clumped them all into one listing without separating them by style). They do have an OEM color (red). Initially when I bought them I did it via western unions but I told him if he really wanted to sell a few of these to put them on ebay.
No it's not difficult at all. All you have to remove is the wheel, open that little door and unscrew the reflector. There is a little rubber gasket that you can remove, or like I did pike a hole in and fish the wire through. Then you just loosen the rear inside trim (push tabs and philps screw) and using the supplied, r your own style wire taps tap the wires you want to have them function how you want.Thanks for the info. I'll check these things out but it sounded like adding the rear fog is difficult to make it looks like from factory, especially the light switch! It's too bad we can't have this feature in NA version!
Well, if it's the diesel, it is a TT.Looks good, curious...did you actually slip twin turbo's in there or is that just a badge? If you did, I'd love to see photos of your setup.
I did mean power folding outside rear view mirrors. People here in Taipei fold outside rear view mirrors almost all the time while the car is parked to prevent other cars hitting these mirrors too easily as the street is narrow and the space for parking is tight.^He most likely means power folding mirrors, which we don't have in the US.What do you mean powered outside mirror switch, which is not available in the U.S.? My side mirrors are poweredand I'm in Wisconsin. Are they the heated mirrors? I thought we had those as well?
That is true (if it's the D)...this would have been a good optional motor for the US.Well, if it's the diesel, it is a TT.
Ahh, I see said the blind man as he picked up his hammer and saw! I don't know if I would ever use that feature. If needed I just fold the mirrors in manually. What I would like is the window switch from the Mazda6 that allows auto up/down on all windows.
