So finally I got around to installing a pair of LED headlight bulbs purchased off eBay a couple weeks ago. Here is the link to the specs:
LINK
Haven't gotten around to taking pictures as it's past midnight but I moved over to these LEDs from Morimoto XB35 HID (4300K)from TRS. This quest started when another vendor was selling H11 LED headlight bulbs. I was curious to see if LEDs are truly ready for prime time headlight duty. The bulbs fit in fairly easily (especially after you have tried installing HID bulbs on a non-tech). Took all of maybe 15 minutes to remove my HID kit and put in these LEDs. Pictures are pending (charging the camera currently).
Observations so far:
- Light output against the wall is fairly close to HIDs
- Pattern and cutoff is similar to the HIDs
- It's nice to not have ballasts (or a relay) as everything is enclosed inside the heat sink behind the LED
- The bulb is hefty, all surfaces I can see (besides the emitters) are metal
- Documentation indicates the bulbs use Cree XM-L emitters (and they're bright)
- The light output is indicated on the packaging as 6000K but it is whiter than most 6000K HID kits I've seen
- Instant on to full brightness (whereas HIDs need to warm up)
Yet to determine:
- Throw distance of the headlight
- Longevity/reliability of the bulbs
- Glare
- Ability to light up reflective signs and road markers
