Reconfiguration of After Market Interior Trim Pieces
sylva143
2014 Mazda CX 5 GT
Also posted in "What did you do for your CX-5 today"
Last summer I posted some pics of a partial dash kit that I ordered from Sherwood. After living with it for 9 months, I decided to remove some of it and also add an additional trim piece ordered from the Chinese Aliexpress website. I am happy with the results.
The new chrome trim piece replaces the molded plastic/rubber dash piece from Sherwood. I was very pleased with the new Chinese part; it looks OEM and fits perfectly, and it adds just a bit of bling to make the dash a bit more interesting without disrupting the continuity of the black interior theme. I can guarantee that nobody will recognize this piece as an add-on (unlike the Sherwood piece).
I also removed additional dash kit pieces from the steering wheel and along the top of the glove compartment. I have a newly found appreciation for simplified look.
Removal of the dash kit pieces was fairly easy. I used a blow drier to soften the adhesive, then slowly lifted it away. Whatever foam remained in place was soaked with Goo Gone then rubbed away with my thumb. A couple of areas along the top of the glove compartment have some slight hazing, but I plan to place a coating of Wipe New which I have found to be a long-term solution for interior plastic issues.
I was very happy with the buying experience from aliexpress; the product arrived in about 10 days. Although the trim piece was bent during shipping, it was easily worked back into place and now fits perfectly.
That looks good. It looks like it matches with the trim piece around the shifter. How does it attach, 3M tape?
Do you have a link for it?
From commenters I've read on this forum, and on aliexpress itself, they suggest replacing their tape with your own 3M.
My big concern is the quality of their "Stainless steel". Reviews on aliexpress for other "stainless steel" products (interior and exterior) trim pieces, complain that they are discoloring. It is hard to gauge how widespread this is on any of these products, since like you mentioned, there are dozens and dozens of different sellers selling the what looks like the same products.
I can tell you that it isn't actual stainless steel, but it does appear to be some compound with a glossy metal film. It looks almost identical to the interior trim pieces that come standard in the interior and appears to be a similar type of product.
If it fails, then I'm not too worried about removing it or replacing again.
