No light behind the back seat ?
zzrobot
Mazda Cx-5 2014
Just helped my son pack his car up at night, couldn't see anything behind the back seat with the rear open, am I missing something ?
one of my complaints not enough lights in this car, no glove box, center box rear sides, trunk light need one on top..... oh well, they try to make it affordable and lighter.
Yes, even if your turn the trunk light on, it is terrible...
Mine's fine...
attachment.php
http://www.mazdas247.com/forum/showthread.php?123831398-Spot-the-Lighting-Mod
does the trunk light turn off when the trunk is closed? I cannot locate the switch.
Yes, it turns off automatically.
Switch is on drivers side of cargo compartment, it's covered in owners manual.
hum, just noticed it was on more than 15sec after the trunk is closed. maybe I need to reset.....
ah, after searching the forum is the back control module, I remove the bulb to check Wattage and see if I can change to different bulb then, it stop turning off when the trunk is closed or car is locked, I can only use the switch.
that sucks, I hope they will replace it under warranty, I wonder why this unit is so sensitive, lots of other guys did the LED change and caused the same thing. I didn't even change the bulb just replace, maybe I shorted the ends? who knows.
