Does the CX-5 need capacitors to run properly without flicker or 1 turning on and the other not turning on? I have a 35W kit from a previous kit and will use new H11 35W bulbs. Thanks in advance!
Mine is a complete kit, installed all in once, no flickering problem. Not sure about if it needs capacitors.
The kits has ballast, heavy duty relay, plug and play harness and H11 bulbs.
