BC's do the same thing, but eventually in the rear you will hit the e-brake. I am already 1-2mm from the e-brake with 20mm shorter struts than stock. This is also with the correct spring preload as I do not want to just let my springs droop.
Oh ok I see. Yeah I'm pretty much on the ebrake in the rear as well.
