I have a question for those that used plasti-dip.
Has anyone used the Plasti-dip primer? Its supposed to make it a more permanent coating.
How durable is the coating?
Does the coating actually seal form water, and prevent rusting?
The reason I ask, I was thinking of starting some rust control on the 7, and since the stock white paint from Mazda is junk and flaking off, I was going to hit a body panel at a time with a wire wheel, then use a sealing primer to prime the bare metal, then was thinking of just using plasti-dip in white. That way its easy to repair, hopefully durable, and cheap. I'm not looking for high grade show car look, just cleaning up a bit.
