I read your thread... Or is it because the lower factory cross bars would cause the roof box to hit the shark fin?
This
The factory crossbars mount
insidethe roof rails, not on top of them. It is my opinion that the factory crossbars would not allow the box to clear the sharkfin. The the bottom of the box would be set 1/2"-1" down below the top of the rails, not 1 1/2" on top of them, creating clearance problems.
I hadn't thought about the width-I haven't measured the space between the bars.
With crossbars on top of the rails, you now can use the full width of the bars. I can put my box on one side, and my mountain bike on the other, or the box and my 9' surfboard- you certainly couldn't do that with the factory crossbars.
One other thing to consider- there are mounts that bolt directly to the hard points (where the roof rails are bolted), eliminating the need for the roof rails altogether. It's a pricey solution, and if you already have the rails installed, may not be cost effective.
I've gone in this direction because I've already got a Thule rack system, with lots of different attachments, and it just cost me the Crossroads feet to put it into service.
I'll go out on a limb here- your box
will work with a solution similar to mine-it's shorter than mine, and mine works just fine.
EDIT:
I got to thinking- your box is 7" shorter than mine. if you look at this pic:
The box as it is mounted is only overhanging the fin by a few inches.
I wonder if that 7" will make the box
short enough to not even reach the sharkfin (whn mounted as far forward as possible). I am assuming the mount for the box is similar to mine and has some measure of fore-aft adjustment.
I think the only way to make sure (short of buying the whole rig) is to take some accurate measurements to determine placement. Maybe mock up some crossbars out of cardboard, and use a 84" length of cardboard to simulate the box. Then you'd know pretty much for sure.
