Rockin03mp5
- '13 Mazda3 / '13 Edge / Your Mom
Welcome seor...
where is the old welcome pic sir? i miss it!
Welcome seor...
To me (I'm no expert though) it looks like the cams could come up juuuuust a bit. Then clamp them together like the pic to keep them put then try to get the crank lined up and the belt on. Give that a try. Everything may not line up absolutely perfectly since there will be some slack in the belt without the tensioner. But with the tensioner pulley/spring it should all line up. Take your time and you'll get there. (2thumbs)
basically the cams are in the exact same spot, only now the bottom bit looks like this
https://skydrive.live.com/redir?resid=50C06A9C62DCD437!815&authkey=!ANssJtXsqW7mshA
https://skydrive.live.com/redir?resid=50C06A9C62DCD437!816&authkey=!AFca2p1V0M19i3k
I have the tensioner in too so im not sure which way is better. Obviouslyid like them to be spot on but that seems impossible as of right now. IIRC, the cams weren't perfectly in line when we went to take the motor apart the very first time... Could it be the cams aren't stamped bang on TDC?
Still doesn't look right.
It seems that the exhaust and crank pulleys have the right number of teeth between them, but I suspect that the intake cam needs to be rotated one tooth counter-clockwise. I know this won't be easy, but that should get everything lined-up correctly. Don't be afraid to use a wax marker to help you line things up, it sure as hell helped me!
As you said, having the tensioner on will make it easier to check if everything is lined-up properly. Make sure there's no slack on the belt when you're checking the timing marks.
Thanks for helping out, Nick. I think you've done your timing belt on your FS too and I'm old so my memory isn't all that great.
I think its bang on now
https://skydrive.live.com/redir?resid=50C06A9C62DCD437!817&authkey=!AAUqZwEqn2Axo2o
https://skydrive.live.com/redir?resid=50C06A9C62DCD437!818&authkey=!ALw0FGrfLUpdkqg
https://skydrive.live.com/redir?resid=50C06A9C62DCD437!819&authkey=!AInyHNH6T929-Yc
Pic for show at the bottom
EDIT: I should thank both of you guys for helping me out! I owe it to you guys for helping me do the most tedious part! Anyone know how large the radiator is? I've drained it all out and as far as I know, the block is dry along with the head. Im kinda nervous about leaving the cap off. Any tips on how to fill it up???
