Question about TPS sensor
mazdarichie
2003.5 Mazdaspeed Protege
How would the car run with a bad TPS sensor? Would it even run or would it throw a CEL? I just can't figure out why the car runs so bad after it gets up to driving temperature. I have replaced the IAC valve, EGR valve, Both o2's, WGA, Vacuum lines, Fuel injectors. Car does not throw any CEL's since I replaced the WGA but it still runs terrible! Runs fine when it is cold but once it gets to operating temp it runs awful. Idle is real irratic.
TPS should be throwing a code if it was bad, but then again I had issues with my MAF and it wasn't throwing cel....you have thrown a lot of parts at it already and i'm sure you are tired of doing that so I would just try cleaning the TPS to see if it makes a differance or not, also check the MAF sensor to see if it's dirty or anything
I am sick of buying parts for this car. I have already cleaned the MAF sensor. I just ordered new coil packs. Might as well try that. Seems like this is a problem many owners have had or are having. Lots of suggestions but nobody seems to have really pinned down what is the actual cause of this. So I guess I will just keep trying. Have to smog this car soon and I need to get it running right. Been so long since it ran good that I can't even remember when that was.
Check your fuel pressure. Mine was a faulty pump. Idle bounced around. Installed wideband and was running crazy lean. Fuel pressure was below normal even at idle. After hard acceleration shifting to neutral would almost always almost cut the car off
