Question about replacing my valve seals.
im2bad4ya
Contributor
MAZDASPEED Protege 2K3.5 #882
Does anyone know of a place or shop or store that rents or loans the tools I need to replace my valve seals? Since our valves are inside the head I can't use a regular valve compressor, I need the one that looks like a lever or whatever. Can anyone point me in the right direction?
I was able to git r done using a large c clamp, a block of wood, and a spacer made from a piece of aluminum tubing.... but there are tools specifically for compressing the valve springs on OHV engines like this: https://www.amazon.com (commissions earned)
I don't plan on removing he block from the head and the springs are deep inside the block. So my question is how were you able to use the tool you showed me?
I think what he's saying is that replacing the seals with the valves still in the head will be an... "interesting" job. I'm not even sure how you'd go about that.
