UPDATE UPDATE!!! (yippy)
I wish I hadn't taken off the intake manifold first, but oh well, I did and after that check, everything was good.
Then I thought, 'what the hell, let me swap over the EGR, couldn't hurt' and that's when I solved my idle problem! It's back to normal, well, almost.
Even though the car idles properly now and doesn't die, I have a high vacuum of 15 In Hg and my wideband gauge is telling me that I'm leaning out (so much that it doesn't give a reading). After initially starting the car up, I'll get a A/F of 14.7 and then in the span of 5 seconds it'll creep up from that to 17 and then no reading. I wouldn't be surprised if this caused my first two engines to go in the first place. So before I make it a third, I need to know what things to check or what needs cleaning, replacement, etc. I'm almost back on the road, help me get there!!
EDIT: I just got the wideband gauge and didn't have it through the first two engines, though I did get the vacuum gauge when I got the car, and initially I would get an idle of 20 Hg In, then after 2 months vacuum idle would be about 16-15 Hg In.
