i had to adjust my drivers side headlight. there was a huge gap on top and bottom. i removed the headlight a put a pipe between the frame rails, and the core support and pulled up to bend back the front lip of the bottom of the core support which allowed the headlight to move up about 3/4 of an inch. then i redrilled the hole on the plastic part of the headlight where the bolt is suppossed to go, so the headlight would continue to fit flush with the fender. it took about 10 minutes to do all of this. then for bumper sag i have my clips to pull up the side, and i drilled 2 pieces of plywood to my bumper under the headlights to make the bumper sit closer to the headlights. and because i have a sedan bumper support, i had to cut it a little higher to allow the bumper to travel the extra inch upward on the drivers side.
looking at the front of my car, youd never guess that i ran into a wall this winter
