Best of luck dude! I'm sure it won't be easy but I know (being a prior MSP'er) that the MSP community will thank you for not letting one more go to pot.
Are all rear motor mounts the same for our cars? Or are the ones with the auto tranny different? The autos just get a softer duro, right?
what does this go to? It's under the dash above the brake pedal.
[/IMG]
I was just looking into the egr valve delete plate. Having so many problems with my last msp's egr I def will be doing this too.
I meant looking into and plate. Wow i'm tired lol. I have heard the one SU sells for the speed 3 will work. For $19 I might have to find out for sure. From the pics it look like it should.
A delete plate shouldn't be hard to make. Just trace out the gasket on a sheet of metal and cut it out. However to trick the stock ecu to not throw a CEL is another story.
I'm trying man. Insurance people are gonna call me today so we will see what happens.
I really miss my car :'(
Thanks man. Just worried about what they will say about me not having an OEM crash bar...
crashbar shouldn't matter they are only rated for 5mph crashes anyway. i don't know what they are going to do when they see your rad support is bent and that the frame rail is touching the crank pulley. did your fmic make it?
My springs are worn out and looking for something to replace them with. Any recommendations that aren't going to set me back a lot. And not many companies offer them specifically for the speed, so I'd like opinions on what the ride height will actually be after the install. I'd also like something that would pair nicely with my Illuminas that I've always got set on the stiffest setting.
